If you are handy enough to take the back off the set, look at the caps (capacitors) on the main board, I had 4 popped on my samsung with a similar problem. $4 repair.
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
if you have any external devices plugged in such as mice or hard drive or usb unplug them and then try to reboot. check online for the brand name of your computer for "safe Mode" typically its hitting the F buttons or the delete button and going into safe mode then if it will save the file you really need. then try to reboot
If you don't see windows, then it's a BIOS password, and you would know if you set one. Unplug it and hit the power button, then touch metal, and pull the battery out for ten minutes. After you put the battery back in the motherboard, and plug it in you need to hit delete at start and enter the BIOS to set the time and date, then move over to exit and save changes.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Step 1: Shut down your PC completely. Step 2: Turn on the Power button. Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.) Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration". Step 5: Select that and HIT ENTER.
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
