Nautica Blue Dail Yacht Chronograph Watch for Men Logo
A
Anonymous Posted on Jun 16, 2012
How do you reset a N15515 Nautica watch
Stainless steel water resistant 100 meters japan movment
2 Related Answers
A
Anonymous
  • Posted on Oct 15, 2007
SOURCE: watch band repair
Cleaning yellow Nautica plastic or rubber wach bands
Anonymous
  • 19 Answers
  • Posted on May 24, 2010
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
2answers
Wenger Watch. I am looking for the right attachment that connects the wrist band.
Do you have a model number? Most watches use a spring loaded pin that slots through the strap at the watch end. The two pairs of 'legs' at each end of the watch have dimples on the inside flat surfaces that the spring pushes the ends of the pin into. You mount one end into a dimple then push against the spring until it's short enough to drop into the opposite dimple. A real pain in the tailbone to do as the bits are so small but you can do it yourself.
HOW CAN I FIND OUT THE MODEL OF MY WATCH, WITHOUT THE MANUAL... THANKS
Model id. is found on the back cover,after the module nbr in a frame.For ex.AW-500,GW-6900,GA-100 etc.
Jan 28, 2014 • Watches
How much
The Abyss 10.900 is a waterproof diving watch that features a silicone filled stainless steel case and stainless steel unidirectional bezel on a black rubber strap. Silicone is denser than salt water, making the Abyss water resistant to grater depths. 10.900 is the depth in meters of the deepest location on earth, the Marina trench in the Pacific Ocean. The refractive index of silicone enables you to see the dial and hands from any angle under water. You can typically buy this watch for about $425.00
5helpful
How do I remove watch band links from m Stainless Steel Nautica Watch? Model #A45001G
2answers
Watch band repair
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
