The silent mode is turned on and I want to turn it off
mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering
system, the phone exits silent mode
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
SOURCE: how do you trn a uniden D1660 cordless phone off
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
SOURCE: my phone is in silent
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download a copy of the manual.
SOURCE: turning off silent mode on dect 6.0 cordless phone
SOURCE: i cant seem to turn off the silent mode on my phone
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
You can silence the ringers on the base and handsets at the same time. It doesn't affect the visual ringer on the phone in standby, press and hold Silent on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on handset. (The answering system answers any incoming calls without playing anything through the speaker.)To cancel, press Silent again. If you turn the answering system off while Silent Mode is on, the phone turns off Silent Mode.
