Thermador MBBS Microwave Oven Logo
Tim Nilan Posted on Jun 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Thermador microwave, mbbs 01 oven: the buttons chrip; timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Jun 17, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718861
Points
48227
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
2 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Apr 02, 2011
SOURCE: thermador built in microwave turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Anonymous
  • Posted on Sep 15, 2009
SOURCE: TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Looking for a service manual for Thermador MC30WP/01 speed oven
The transformer that supplies the magnatron is fed from the same part of the machine that feeds the turntable motor.
The turntable motor is fed through one of the door safety switches.
Check the door switches and feed fuse. If a diode pack has failed, that will blow the fuse or even damage the switch as well.
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Thermador opion 3 micrawave does not work
First if it has a turntable and everything lights up etc, does the table move or not? If it does but no heat/cook possible inverter board or even the Magnetron unit.
If table does not turn it may be a safety switch located in the unit that is not engaged (have to get at from inside unit).
Thermador built in microwave turns on but wont heat worked great this morning. model# MBBS/01 serial# FD8602
heatman101
Panel works. Timer works. Light works. Does not heat. Makes no sound. turntable does not turn.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1helpful
2answers
My thermador microwave model mbbs makes a lot of noise and does not produce any heat output.
Basic
heatman101
1helpful
2answers
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Top Thermador Microwave Ovens Experts
Paul Bade
john h
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
