Fully charge your iPod touch to prevent draining your battery during the factory reset.
Touch "Settings" on the device's Home screen.
Select "General" from the "Settings" menu.
Choose "Reset."
Select "Erase All Content and Settings." A confirmation window pops up on the bottom of the screen.
Touch the red confirmation button on the bottom of the screen.
hope this helps
To set a minimum font size for messages:
Choose "Mail, Contacts, Calendars" > Minimum Font Size, then choose Small, Medium, Large, Extra Large, or Giant.
Also, you may need to try the following:
Restarting and Resetting iPod touch
If something isn't working right, restarting, force quitting an application, or resetting iPod touch will likely solve the problem.
Restart iPod touch: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPod touch. To turn iPod touch back on, press and hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPod touch or if the problem continues, you may need to reset. A
reset should be done only if turning iPod touch off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPod touch
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPod touch: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
This information was sourced from the iPod Touch official user guide at:
http://manuals.info.apple.com/en_US/iPod_touch_3.0_User_Guide.pdf
Hope this helps.
Best regards,
CellPhBuddy.
