Sharp Viewcam VL-NZ150U Mini DV Digital Camcorder Logo
Mohsin Khalid Posted on Jan 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp VL-DC5 hi there i have a view cam of sharp vl-dc5 mini dv i have tryed alot to connect it with my computer through usb but when eve i connect it my pc gives a msg of unknown device. i search its driver on the internet but they say windows xp has its driver in it .if windows has a built in driver then why i cannot connect it with my pc. plz help me with this regards Mohsin Khalid.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
491
Points
Hola a todos pucha tengo un problema con la cam vl-cd5 si alguien me pudiera ayudar lo agradecere mucho la tengo ace como un aã±o y no la puedo traducir a espaã±ol o ingles la configuracion no se si esta en chino o japones y la kiero traducir
de ante mano si alguien me puede ayudar
un abrazo para todos
mi mail es [email protected]
agradecere cualkier ayuda compaã±eros
un buen dia y espero alguna respuesta
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Jan 29, 2007
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1637792
Points
8444
You should have the driver on the cdrom that came with the cam, as it may well be hidden within the software if you have'nt installed it. But if the problem continues, uninstal the current drivers in add/remove programmes and re install and add your cam to a different usb port than before, although i would of thought firewire connection would be more suitable for speedier transfers.
I WANTS SHARP MIN DV VL-DC5 DRIVER
Hi there
Okay so I have carried out some research on the problem you are having.
The VL-DC5 does not have drivers online to download because the drivers in windows XP support this model camcorder
The problem is that you are probably trying to connect the device to your computer using USB.
The drivers in windows XP are only compatible with this camcorder when using Firewire cables.
If you don't have a firewire cable then you will need to buy one and use this to connect your camcorder to your pc.
It should work fine after you have tried this.
Let me know how you get on!
I need the part # that will allow me to connect my Sharp Viewcam Z VL-Z1 to my computer to download video. Please help.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can usually be found on Amazon or eBay. Try a search on your camera model number. Most cameras need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
I am looking for a instruction manual for a sharp digital viewcam vl-nz50, do you know where I cam get one?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Download correct software to burn dvd off of camcorder
You do not need the manual, you need the white DV cable that comes with the view cam. it connects into the DV port on the left side of the camera theto the "Y" port located next to the usb ports in the front of the hard drive. Turn the camera to VCR and XP will automatically open the CD wizard and follow the prompts. then use any burning device on your computer, mine is Media Center to make a DVD. Its easy for those challenged like myself!
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Want to transfer videos from a mini DV cassette to computer.
Hi
Basically what you need is a video card in your computer. Then you can connect your AV/S cable from the camcorder to the computer video card. When you buy a new video card, it usually comes with a free basic editing software which you can use to capture the video on your computer. Hope this helps.
5helpful
2answers
Drivers for Sharp Viewcam VL-Z3E
please send to me driver for Mini dv sharp viewcam VL-Z1
How to get video onto a pc
use your cd to install the drivers onto your computer. Connect camera via usb and use the pixel software that came with your camera or you can use Windows Movie Maker to download your recordings.
Top Sharp Video Cameras Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
