Mitsubishi WS-55311 55" Rear Projection Television Logo
james lawson Posted on Jun 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ws-55311 shows blue screen on all inputs except the DTV input
Not a single input shows anything but blue screen except the DTV input. the menu and volume and all those functions work just nothing from the inputs
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Jun 17, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716043
Points
48227
This set has 3 hidden menus accessed with a different 4 digit number code----You need the Mitsubishi remote to enter.
One of them is the Option menu which will allow a hard reset of the TV back to factory original---98% of the time it will restore all inputs--cures all sorts of odd problems.
If you have that remote and want to try it let me know for sure the model number and I will give you a link to the instructions for doing it.
5 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on Feb 27, 2008
SOURCE: Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Anonymous
  • 1284 Answers
  • Posted on Feb 04, 2007
SOURCE: Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
Anonymous
  • 1153 Answers
  • Posted on Aug 18, 2007
SOURCE: problem with inp-dtv input
Do you have the specified cables and is your TV set to right mode?
Anonymous
  • 927 Answers
  • Posted on Apr 02, 2008
SOURCE: mitsubishi WS-55311 flashing screen
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
Anonymous
  • 115 Answers
  • Posted on Oct 10, 2009
SOURCE: Mitsubishi WS-65809 - works, but screen won't power on.
yes that is correct 12 is normal...make sure all connectors are plugged in and in the correct places . conectors should be marked with letters that match the marking on the circuit board. Then look for heaters , in the glass bottom of the picture tubes(CRTs) there should be a little orange glow visable though the neck of the CRTs just above where the crt boards plugg onto the bottom. if the heaters are not glowing then check your wires to the crt boards again , you probly tugged one of them too hard during disassembly also check for cracked solder in the heater circuit......Oh yeah, you didn't mention -Does the TV get high voltage ??? thats important to having a picture......If you see the heaters glowing when the tv is on then look down into the lenses of the crts . If you see a brite color horizontal line closer to one side in each of them then you know most of the tv is working. If that line is curved then the tv probly detects that the convergence circuit is not working and it is blanking video.
OR -----
the error is 21 (see what number it ends the sequence with..) . Error 21 is X_Ray protect and you probly plugged one of the connectors into the diagnosic connector(near the high voltage transformer- normally nothing goes there) . If that is the case then somthing in the H.V. circuit could have been permanently damaged and now the tv has a new problem and wont work even if you put that connector in the right place.
Testimonial: "Lots of information. Great knowledge on the topic."
1helpful
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Ws 65611 will not play HD channels. Screen gets fuzzy like it is trying to focus, then converts to blue screen that states "Check connections or power. The connections for RGBHV or YPrPb invalid" I have...
This model only has one HD input---it has two sets of component inputs on the back and one is marked 480/1080----in the menu it will be the DTV input.
Check to make sure you are not connected to the other component input.
Let me know what happens and let me know exactly where you are connected and what are using for signal.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
1helpful
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Blue screen with dtv input and HD channels
the left large button controls a dozen different ways your set is hooked up,easest is get the monolink cord at any store will need a dvi hdmi.if not keep rolling the left large button,if you have a blue screen on all your inputs ,There has to a man around to plug in the right cord.
All inputs work except for the component videos.
When your tv shows a blue screen it not getting a signal!! In your mit's you have to go into the customer menu and turn on the input/device. The device control is on the remote, click over to input and activate (enter). Also, look into owners manual, the customer service at mit's will step you through it if you wish. Note: put cables into comp 1 (eg), make sure colored cables are correctly inserted, and audio. (red, blue, green) red/white; audio.
Mitsubishi WS-55311 flashing screen
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
