The drive shaft as brocken just outside the gear box.
To replace it you need to remove the rear assembly then open the rear axle assembly
SOURCE: we have a husqvarna cth 170 and we cant seem to
I have a Husqvarna YTH2348 that clicks when i try to start... I had the battery tested and changed the solenoid and still won't start. How do I check the starter????
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
SOURCE: husqvarna cth
sounds like it has something inside the trans that needs to be fixed i would say you will need to take that in to a shop to have it fixed
SOURCE: I have a Husqvarna CTH 171. When i engage the blades they
Does the lever that engages the blades have pressure on or does it feel loose. It is possible that the linkage from the lever to the idler pulley has come off. Raise the hood and watch the lever as it is engaged and disengaged there shold be somekind of linkage moving a pulley in and out to tighten the belt so the blades will turn. hpope this helps
SOURCE: Self propelled JS63 Deere Lawn
some times you can add a thin shim to the out side of the wheel mounting center to push the wheel gentally a little more to the drive gear for more positive engagement to the wheels inside gearing, also check your gear drive mounting pins/ keys for wear if thier warn it will engage the end of the drive shaft iradically appearing as slipping type movment at the wheel hope this Helps Steve
