I have no problems in pairing or quality or something else. i just want to ask everytime i connect my nokia 5800 xpressmusic to Nokia BH-503, i always received 2 messages from my service provider which is configuration message. i think this is for my mms/gprs settings. i know that my phone is mms/gprs activated but everytime i connect to wireless headset. i always received 2 messages. i also tried other nokia bh503 still the same. but when i try my nokia bh-503 to the other phone, no problem occurs. i am living in the philippines and my service provider is smart.
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
SOURCE: I cannot connect Nokia bluetooth headset BH 209 to my Nokia 5200
0000 is the password .... www.clickmak.com
SOURCE: i have made connection between
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
SOURCE: I cannot pair my blackberry
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
