SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
SOURCE: Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
SOURCE: I have a sears solid state VHS camcorder LXI
The CRT is most likely bad. Unfortunately, i have the same problem and there are no longer any parts available for it. Just in case you do not know what a CRT is, its basically a tiny T.V. screen in the viewfinder. You could use it by hooking it up to a television so you can see what you are recording,but other than that its ready for the electronics graveyard.
