I have charged this battery completely. My scooter will turn on but will not go anywhere . It worked just fine this morning but now nothing. I have asked razor many times for help but have gotton nowhere. Please help if you know anything to help
SOURCE: razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
SOURCE: where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
SOURCE: Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
