The first time I put the new toner in , the light was not blinking. When I printed the paper had a line along the edge. I had to take the toner and drum back out and I realized I had not returned the slider tab back to the home position. I did that, but now the error light will not go off.
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Testimonial: "Thanks!"
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
SOURCE: Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at [email protected] should you have further questions.
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
