I cleaned the lenses and I switched to every setting. and the lines are still there.I cleaned the lenses and I switched to every setting. and the lines are still there.
AnonymousMar 30, 2014
Screen displays vertical lines only. Camera still functions. Can't see what display is showing other than vertical couloir linesScreen displays vertical lines only. Camera still functions. Can't see what display is showing other than vertical couloir lines
You can't post conmments that contain an email address.
This is a CCD break down
Panasonic customer support is the place to go
If it is a recent purchase they will swap it
If it is older they may offer a discount on a replacement
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
I have a Vizio, I am able to go menu>set-up>picture. In that mode I have vertical & horizontal adjustments that fix that problem. Maybe you have similar choices in your menu.
Thus meaning what display on the LCD is exactly what "enters" through the lens. Is this a hairline or thick line appearing on the LCD and does the same happen on the photos/pictures when they are downloaded on a PC? If so "something" could have infiltrated into/onto the camera lens....
My E550 started producing over exposed frames (everythings white except maybe across top) with lines.This just happens outside.On inside the pictures are great.
BGibbons
