Panel reads F7 in red and flashing e6 5a 57 58 in green
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0 and F1
Failed Thermistor Control
Replace Electronic Range Control (ERC)
F2
Oven temp exceeds 590 w/ unlocked door
High resistance or interference in oven temperature sensor. Replace oven temperature sensor
F3
Open oven temperature sensor circuit
F4
Shorted wire (Oven temperature sensor)
Locate and correct
F7
A = Function pad button stuck or
B = Bad clock
Unstick button or
F8
Component Failure
F9
Program w/ door circuit
Check wiring
