When i turn on the machine it goes through the normal check. Upon warm up and initial scanner sweep the error code sc41-03 shows on the LCD screen.
SOURCE: I have konica mionolta bizhub pro c500 when i
The problems is into fuser unitmCheck the thermistors,thermofuses,heater lamp and the rapis fuse.
SOURCE: error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
SOURCE: Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
SOURCE: Konica Minolta Dimage scan dual
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
SOURCE: The Negative Holder is stuck
In this case what you can do is :
1) Uninstall the Scanner Driver Software from your PC
2) Check All the cables of the scanner are properly connected.Check both DC terminal and USB.
3) Restart the PC
4) Restart the Scanner (Switch Off and the switch On after 1 Minute)
5) Install the Scanner Software Driver in PC and check.
If you feel that my answers/advise have helped you getting
solution to your problems then please Accept the solution. Thanks.
If the problem persists then you can open the Negetive holder but for that take the help of the following link i have given below. Click on the link and a pdf document will open in which you can find detailed description of the scanner and procedure to open the Negetive Holder.
http://download2.konicaminoltaeurope.com/OpenMind/Technic/Document/manlibph.nsf/CBA6A8A8B8722900C125711E00468228/$file/DSE5400-2_OM_E_.PDF
