Laura Hackman Posted on Sep 20, 2017
Connecting a product that had been returned and reset to internet and wifi
I am unable to connect to my own wifi (cell com). I've entered the SID, did not put in a password. Get "remembered, not in range". My neighbors also have cell com wireless. A network, cell com, secured with WPA/WPA2 PSK, could this be their network? Why would this show up and my own be out of range? My PC indicates the connection strength as excellent..
5 Related Answers
A
Anonymous
  • Posted on Jul 25, 2008
SOURCE: Connecting to Internet with WiFi
WITH YOUR WIFI CARD IN GO TO
START ,SETTINGS,CONNECTIONS,THEN TAP ON THE WIRELESS ETHERNET.
YOU SHOULD SEE YOUR NETWORK NAME THERE.
HOLD YOUR STYLUS ON IT FOR 203 SECONDS TO GET THE
CONNECT/REMVE SCEEN.
THEN TAP ON CONNECT.
TRY THAT.
A
Anonymous
  • Posted on Sep 11, 2008
SOURCE: apple ipod itouch connection to wireless internet
don't let the iTouch connect to the wi-fi network it detected automatically - try setting up a new wi-fi network from scratch.
the setup screens will ask for network name (the SSID) the security protocol (probably WPA-PSK if you are having all this trouble) and the password (pre shared key)
should be all you need - good luck
Lardman
Anonymous
  • 181 Answers
  • Posted on Jan 17, 2009
SOURCE: Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Anonymous
  • Posted on Jan 25, 2009
SOURCE: my wi-fi isnt working on my itouch!
well...ya'll need mental treatment coz it does work.....try comin' to ma crib...hhaa
Anonymous
  • Posted on Feb 15, 2009
SOURCE: itouch 16gb, Cannot get an internet connection
Hit "Forget this Network", go to Settings > General > Reset > Reset Network. Worked for me.
Connecting to Public wifi?
most public wifi would need you to sign in by accessing some specific page. they still want to know who you are.
3answers
Verify internet connection-not connecting
reset the router by holding in the reset button for 15 to 20 seconds, then wait for all lights to return. If you have DSL wait for the dsl light to be on solid, once thats complete if your using vista and still unable to connect run "diagnose and repair". If after that your still unable to connect, open "run" type "cmd" and hit enter....the type "ipconfig" and hit enter, you should get an ip address, subnet and default gateway. one at a time type "ping" hit space bar 1 time then type the ip address in as shown in the list and hit enter, if 4 return then ping the default gateway, if it returns 4 then ping www.yahoo.com, if return 4 then remove Norton or Mcafee from your system and try again.
8helpful
I am having trouble connecting to internet even when 3g available for several days
under 'settings' -'more' - 'mobile networks' - 'access point names' hit menu key on bottom right of phone then 'new apn' under name enter STRAIGHT_TALK, under apn enter tfdata, scroll down to MMSC and enter http://mms-tf.net, then in MMS proxy enter mms3.tracfone.com, and under MMS port enter the number 80. hit menu key and select save. then return to access points and click on the button to the right of STRAIGHT-TALK.
thats how to fix it i had to do it i got that from straight talk forum
Wi fi adapter all of the suddenly cant connect
There are several possibilities, but without some details I can only guess what's going on. I'm going to assume the problem is on a home network and you're using a current version of Windows in hopes of sending you some quick help, but if those are bad assumptions, please send details.
You can run Windows wireless diagnostics by clicking on the icon that looks like cell phone bars at the lower right hand corner of your screen. Next choose Open Network and Sharing Center, then Troubleshoot problems. That process may solve the problem or it may make a suggestion on your next step.
You might turn off your cable or DSL modem, and then turn it on again.
If you're using a laptop, you might check to see whether there's a wireless radio switch that has been accidentally turned off.
You might restart your PC.
I'm guessing that you know the WiFi hotspot you're connecting to hasn't changed its security settings or name. However, if someone else manages the WiFi network you're connecting to, ask that person if they've made changes.
These should address the most likely culprits. If not, please send info about your computer, your network, whether you can access the Internet outside of your web browser (e.g. can you get email in Outlook), and what you've tried so far.
A wonky PC is the pits. Best wishes on quickly getting it going again.
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
2answers
Can't access to internet connection...though it has wifi signal
Yup its have a wifi signal. But you need a wifi router .like mall they have a free wifi or a computer shop. If you want to open your wifi just 12 click menu-setting-connectivity-WLAN-on your wifi then search.then click the available wifi then if say connected.. You can now internet..
Carnt get my wii online
First, you have to go through the Internet connection setup process through the console and you've made no mention that you've attempted that so I wanted to make you aware of that. On the main menu, go to the lower left corner and click on the round Wii button. A new menu will appear with two options: Data Management and Wii Settings. Select Wii Settings. Go to the second page and choose Internet. Select Connection 1: None. Select Wireless Connection. Select Search For An Access Point. A network list will appear, select yours. You will then be prompted to enter the password/network key that you established when you set up your wireless router. The Wii will attempt to test the connection. If successful save your settings.
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Cant connect to wireless home hub
MY IPHONE 3G IS NOT CONNECTING TO WIFI...IT SHOWS ERRORS AT WIFI
What kind of error? Are you trying to connect to a wifi connection encrypted with a password? If yes, you have to enter the correct password to be able to access the internet.
If the error still persists, try to reset network settings. It should fix all network related problems.
Just go to Settings > General then press Reset Network Settings
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
