Http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=3SLSR6233MQ0&mfgModelNum=&fkMfgID=3
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: RE: Putting whirlpool washer back together
ok I know this is a problem heel i had trouble doing y first few but i learned a trick 1. make sure your front feet are off the ground at least 1/2 inch if they are rusted or broken place a screwdriver under the black rails. ok 2. wirh the cab. in front of you open the lid andhold it under that lip tilt it forward and then slide it toward the unit look down the lid hole you want the front edge to line up first as you slide it down there are two flat pins sticking up on both sides about 7" back fron the front corners these must fit into the cabniet you then drop it down slowly put the left clip on first then place you hand down the back right side pull it forward and install your other clip one note the fill dispenser will need to get under the cabniet before it will seat properly. connect your lid sw and close the console. let me know if this works and please rate this help
Thanks Gary
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
SOURCE: Need Diagram of How to Reassemble Agitator or Whirlpool Top Loan
LXR9245EQ1
Thanks for giving the correct model number.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=257320
Click on the diagrams in the left-hand side. You can print them out also. They will show how the unit is assembled.
Thanks, but it is the actual wiring at the back. He cant remember where the wires go
