Does anyone one know how to get the embroidery stitches to work on this machine ? !
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
SOURCE: Toyota T50 Quiltmaster
You can get a replacement manual from www.IFixMachines.com I've got a 50% off coupon code that may still work savehalf. I don't think toyota is still in business.
SOURCE: i have a huskystar em10 embroidery machine which
I have the same machine and had the same problem. I was changing my needle about every 50 stitches until I realized that it was the timing. After I learned how to adjust the timing the machine has worked fine. The problem is I have to adjust the timing about every 3000 stitches. I leave the bottom off of my machine because I adjust it so often. If you contact a husqvarna dealer they will tell you that they have to send the machine off to get it adjusted and that you can't do it yourself. I didn't have time for this so I googled how to do it and figured it out.
SOURCE: our toyota Rs2000 quiltmaster 50 is not picking
1.is the needle bent or blunt
2.is there a 2 to 3 inch tail on the bobbin that it can be picked up
3.is there lint or thread fragments in the bobbin aea
