I need the technical electrical information for my electrician to install a new plug outlet for my new range.
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
