Motorola Mobility Elite Flip Bluetooth Headset Earpiece Hz720 Hz-720 89504n Logo
A
Anonymous Posted on Apr 27, 2017
I just bought the Elite Flip earpiece. It is pairded. While driving I receive a call I have to retrieve my 3G I phone, turn it on, accept the call, then press the elite flip bar in order to use it...what a pain. When I wish to make a call, I similarly have to turn it on, push and hold the main button until the Voice feature comes on, then announce my call request, then switch it over to the Flip again. This can't be right...can you help me. I thought all I would have to do was push the button to either make or receive a call. Thank [email protected]
Dennis
Level 3:
Top Expert:
  • Master 1,057 Answers
  • Posted on Apr 27, 2017
Dennis
Master
Level 3:
Top Expert:
Answers
1057
Questions
Helped
441130
Points
13558
It *should* connect to your phone by just pressing the call button with a call comes in. (They all work this way). My guess is, based on your description, is that you are not just pressing the call button, but holding it. This resets the headset back to default and unpairs the phone. When you receive a call (after making certain it's paired) is to just tap the call button once.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Aug 07, 2007
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Anonymous
  • Posted on Sep 08, 2007
SOURCE: my headset wil not turn purple after holding it for 5 seconds
You need to hold down the call button before opening the mic. Once it turns purple immediatly open the mic. If you wait too long to open the mic after it turns purple it will turn blue or just go out.
Anonymous
  • Posted on Dec 07, 2007
SOURCE: No sound from BT
put up the volume
Anonymous
  • 8 Answers
  • Posted on Jul 04, 2008
SOURCE: Trouble getting motorola headset to pair with my samsung phone
Here is what will work.
Fold the microphone in the closed position on the headset.
Now hold the button down and open the microphone out while still holding the button down. Assuming that you phone is in the Bluetooth mode searching for a device, you should see your headset listed.
Anonymous
  • 65 Answers
  • Posted on Aug 05, 2009
SOURCE: H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
I just purchased the Motorola Elite flip bluetooth and, Can hear fine on my end, and there is alot of background noise and it was advertised as not having any background noise, but thats nof the rea
Alesia-
Will help you in this one. How do get my Motorola Elite Flip bluetooth headset to stop echoing on the... Since it is the same question.
Mark
Motorola Support
Turning 3G Off
this might be you can find in 5th number Option "Network" on phone
try it and revert
good luck!
1helpful
How can I accept my memory card
help if how to use yahoo keitai? because if i search google in yahoo keitai ............always response is disconnected............
4helpful
2answers
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
I dropped my cell phone on the floor the screen now looks like the white fuzzy screen on a TV when it is off the channel, I can still receive phone calls and they can hear me but I can't hear them. I have...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
On the other hand, the problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Earpiece not working
I have the same problem. By any chance have u fixed the problem since last year? Do you remember what you did?
Unable to receive calls without using speaker
While receiving a call press < or > on the side of the phone this will turn the earpiece volume UP or DOWN a visual bar will appear on the screen. Do this during a call.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
