Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printhead problem (black/yellow) on HP L7780
A piece of paper jammed in the machine which I extracted, but now I get the error message "The following printhead(s) has a problem: black/yellow. Can't get it to go away and don't know what to do. Help!
  • 3 more comments
  • stephaniem16 Jan 14, 2009
    I was setting up my brand new HP 7380. It printed the first test pages ok and then when I went to print something else I got a paper jam which I cleared and then got the same error message "printhead problem with black/yellow. I removed the printhead and put it back in pressing firmly etc and then I got the same message only now the magenta/cyan has the same problem. When I look at the status of the printheads they are both showing a red dot. It won't clean or align or do anything at all! Also tried turning if off and unplugging power. To no avail.
    Steph M
  • BWT-GUY Mar 05, 2009
    Paper Jam followed by the Printhead Problem - Yellow/Black
  • devo80109 Mar 07, 2009
    I've replaced all of the cartridges correctly and it still says that my M/C printhead has a problem. How often do these need to be changed?
  • dvandy Mar 13, 2009
    I had the same thing happen -- paper jam-- then black/yellow (K/Y) printhead message
  • Anonymous Mar 23, 2009
    is there any fix? maybe I have damaged the head somehow - is it Not worth repair etc
    Scholar:
  • 81 Answers
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges printhead problem (black/yellow) on HP L7780 - c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold thprinthead problem (black/yellow) on HP L7780 - c00847980.gife button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard coverprinthead problem (black/yellow) on HP L7780 - c00848392.gifnthead carriage. Figure 3: Remove the cardboard cover c0084printhead problem (black/yellow) on HP L7780 - c00848393.gifss=
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shprinthead problem (black/yellow) on HP L7780 - c00847983.gifhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remprinthead problem (black/yellow) on HP L7780 - c00847984.gife protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all thprinthead problem (black/yellow) on HP L7780 - c00847987.gif, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Posted on Dec 01, 2008
How to change the print heads on the HP all in one 7780
Posted on Dec 20, 2008
Call HP. Stay on the phone for about an hour. Try their solutions. After that they will replace the printer.
Posted on May 18, 2009
May sound awful, but if you put a paper towel or two between your mouth and the printer head (where the link comes out) and **** it will work. Will bet money on this! Let me know if this works 4 u
Posted on Nov 09, 2011
SOURCE:
I installed a new black cartridge and my L7780 is still telling me to replace the empty ink cartridge
You may want to try the clean the printhead:
  1. Press the Setup button.
  2. Select Tools.
  3. Select Clean Printhead.
Oct 29, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
The following printhead has a problem black/yellow the printer will not print. These are new ink cartiladge
Hello and welcome to FixYa!
In the HP OfficeJet Pro L7780 the printheads are actually separate from the ink cartridges. In your case, it sounds like the black/yellow head has worn out and will need to be replaced. The good news is, this is a user replaceable part. The bad news is, the replacement heads are not cheap. Amazon has the HP 88 Black/Yellow printhead listed currently for about $61.
http://www.amazon.com/HP-Yellow-Officejet-Printhead-Packaging/dp/B000BO9L8M/ref=dp_cp_ob_e_title_0
YouTube has a nice video that explains how to install the printheads here:
http://www.youtube.com/watch?v=8Zl0LUxBSvg
I hope this helps!
Mar 02, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Where is the print cartridge can't fix jam
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 12, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have three HP L7780 printers that have bad print heads black/yellow. replaced but same problem. ?????
take out printheads. unplugg power cable from back press adn hold down 6 and # buttons on pritner at same time while holding them down plugg it back in. then insert printheads one by one. first insert black/yellow shutt the door adn check for message on pritner screen. if it says printhead missing cyan/megenta it means it detected black/yellow printhead. do same with cyan/megenta adn check for message on screen. if you see no error mesage and both printheads were detected fine let the printheads alligned completely. then if u see same issue it is the pritner whgich need to be replaced.
Dec 15, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Nov 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printhead Problem
Open the cover and hold the cancel button for a few seconds, the carriage moves to the left side. Pry off the cover on the right and look for any paper scraps down in the cavity. You can also remove the m/c printhead and wipe the bottom on a damp paper towel and try again...
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
10,752 people viewed this question
Clive
Clive
Thomas F. Schneider
