If your computer has XP try these steps.
1 Turn on the computer.
2 When the
Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
NOTE: Some systems like Inspiron Mini 9 (910) do not support System Restore as they do not have <F11> nor any substitute.
3 In the
Dell PC Restore by Symantec window, click
Restore. Alternatively, press <Tab> to highlight
Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click
Confirm, or press <Tab> to highlight
Confirm and then press <Enter>.
The
Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click
Finish or press <Tab> to highlight
Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
If you have Vista try these steps.
2 As the computer starts, press <F8> on the keyboard until the
Advanced Boot Options menu appears on the screen.
Note:
You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the
Advanced Boot Options menu will not appear on the screen. If you do not see the
Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the <Down Arrow> on the keyboard to select
Repair Your Computer on the
4 Specify the language settings that you want, and then click
Next.
5 Log in as a user who has administrative credentials, and then click
OK.
6 Click
Dell Factory Image Restore.
7 In the
Dell Factory Image Restore window, click
Next.
8 Click to select the
Yes, reformat hard drive and restore system software to factory condition check box.
9 Click
Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click
Finish to restart the computer.
If this does'nt work lemme know with the version of Windows you have.
I changed setup to boot from CD, skipped to boot from raid.
Tried disabling raid and it still would not boot. Would not boot to USB drive either.
TF1021Assembly, COMPACT DISK READ WRITE/DIGITAL VIDEO DISK DRIVE COMBO..., 48X Half Height, TOSHIBA SAMSUNG STORAGE TECHNOLOGY..., BLACK...
YC9523Hard Drive, 146GB, U320..., 10K, 80P Lead Free, Maxtor
3 Drives in Raid 5 Configuration using controller below.
D92051Card, Controller, PERC4-DC, U320...
GH7022KIT..., SOFTWARE..., WINDOWS SERVER 2003..., CAL5D, ENGLAND/ENGLISH...
YC3403Assembly, Carrier, Hard Drive Small Computer Systems Interface, Universal, 1IN, V2
