This is an over the range model and the under the microwave light flickers on and off even though the light touch pad is off. One can hear crackling/shorting when the light flickers on. The light touch pad has a high, low, and off setting, and the flickering occurs in the low and off settings. Probably also occuring in the high setting but not decernable. What is the cause? How do I access the control board--need instructions on removing the face plate to check on wire connections?
That's common - it's a problem on your control panel. We regularly repair these control panels for only $32.50 nationwide. For critical safety info & detailed disassembly info, see our link in our FixYa listing here: http://tinyurl.com/yzjozk Let me know if you need further help. I appreciate your kind rating!
