I need to know how to reset the security code on Moultrie M100 game camera.
SOURCE: how do you erase the internal memory
Power on; wait for menu screen to go thru instructions until in auto mode and countdown starts..press mode button until in setup mode...press up arrow until "Delete all images no"; press select...NO will start flashing..press up or down arrow to change to flashing YES; press select...Done will appear...press up arrow again and you get "delete all events...use same procedure. This info is in user manual which can be downloaded from www.moultriefeeders.com.
SOURCE: I can't find software updates
The only upgrades Moultrie has is for the D55 and D55IR models...and these only reduce trigger speeds...no other software updates available yet.
SOURCE: moultrie m80 5.0 camera will
had to program mine thru setup menu for mode I wanted to use..pressing mode and hold several times works sometimes.
SOURCE: moultrie i40 digital game camera will not flash
run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
SOURCE: moultrie m100 game camera security code reset
the override code is the last code you put in. put it in exactly and hit enter. it worked for my boyfriends moultrie 100 camera.
