Model number FWT449GFS0
SOURCE: FRIGIDAIRE GALLERY 12 CYCLES COMMERCIAL HEAVY DUTY SUPER CAPACITY 2 SPEED MOTOR
see if you have a pump issue, pump not working something in the pump
SOURCE: trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
SOURCE: kenmore washer model 11o 13 years old doesn't agitate or spin
If water does not Drain, follow the below guide to investigate :-
It spins, but doesn't pump
If
your washer spins but doesn't pump the water out, the drain line is
probably clogged. In many washers, a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into
the drain hose that's attached to the pump--or even into the pump
itself. If it's in the pump, you need to remove the hoses from the pump
and pull the item out.
To remove the sock from the outer tub
port, open the washer's main access panel and remove the large-diameter
rubber hose that connects the pump to the bottom of the outer tub.
Then, using needle-nose pliers, try to grab and remove the clothing
through the port.
Sometimes you can't remove the stuck
clothing from below. Then you have to remove the agitator, top of the
outer drum shield, and inner clothes tub. This isn't easy to do--and
you may need special tools--so you might be happier getting a qualified
appliance repair technician to do the job.
If the drain line
isn't plugged, the problem may be with your pump. Even if the pump
appears to be turning, the internal impeller may be broken. If so, you
need to replace the pump.
It doesn't spin or pump
If
your washer doesn't spin or pump water out but the motor is running,
your washer probably has a frozen pump pulley. If so, you need to
replace the pump. To check the pulley, remove the pump from the washer
and try to rotate the pulley manually. If it doesn't turn freely--if
it's frozen or stiff--replace it.
It pumps, but the water returns
If
the water that pumps out of the machine goes back into the machine
after the spin cycle, your washer may be siphoning the water from a
laundry tub that has a slow drain, back into the washer. The usual
remedy for this is to improve the draining of the laundry tub. (Is
something stuck in the drain?) Also, check for these problems:
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Need Manual for Frigidaire Gallery Heavy Duty Washer/Dryer Combo Model #FLSG72GCS0
my washer make a loud sound when spinning
