I need to program Vizio TV and do not have code
SOURCE: NEED CODE
Celera 0765
Magnavox 0054, 0706, 0030, 1454, 1254
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: need tv code list for urc-4605
http://www.ofausa.com/remote.php?type=URC4605
you do
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: code for Magnasonic TV
I have magnasoni TV 14`` and I have Unversal remot RCA in need some help for codes thanks
SOURCE: need code list for rca remote control to program
Hey Keven,
I am not sure what model remote you have so I could not give you a direct link to it. But the link below will take you to Direct TV remote manuals page. Just scroll down and click the manual in the right side column that corresponds to your remote and download the manual. It's in pdf. format so you will need the free adobe reader to view it if you don't already have it.
Just in case you have the remote in the image included with your post (the D770 I think), I included the link to the manual for that model as well
I hope this helps. Please let me know if you need anything more.
http://www.directv.com/DTVAPP/global/contentPageNR.jsp?assetId=3490011
http://www.remotecodelist.com/remotes/rca/RCA-D770.pdf
