The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
