Nordic Track NordicTrack A2550 PRO Treadmill Logo
Anonymous Posted on Jun 14, 2012
The incline does not work - Nordic Track NordicTrack A2550 PRO Treadmill
ernesto cuadra
Level 3:
Top Expert:
  • Nordic Track Master 12,223 Answers
  • Posted on Jun 14, 2012
ernesto cuadra
Nordic Track Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081011
Points
34431
1) Run the software calibration for diagnose, and troubleshooting.
2) However lube the shaft and gear very well, clean, and tight the wire connector.
3) Adjust the potentiomenter for better response. see the diagrams attached.
4) Measure the input voltage elevation motor use the VOM, see the diagram attached. God bless you
What is error code 53? Treadmill only working when incline is 0.5. When change up or down, it shuts down.
Error code 53 typically indicates a problem with the incline motor or the incline sensor on a treadmill. It could be caused by a malfunctioning incline motor or a problem with the wiring or connections between the motor and the sensor. The fact that the treadmill only works when the incline is set to 0.5 suggests that there is an issue with the incline mechanism and it may need to be serviced or repaired by a professional.
What if if dos noting but shows on the display servive 72
If your Nautilus T9.14 elliptical trainer is displaying the "service 72" message, it typically means that there is an issue with the incline motor. The incline motor is responsible for adjusting the incline of the elliptical, and when it is not working properly, the elliptical will display this error message.
Here are some steps that you can try to resolve the issue:
  1. Check the incline motor connections: Make sure that the connections between the incline motor and the console are secure and tight.
  2. Check for any debris: Make sure that there is no debris or foreign objects blocking the incline motor.
  3. Check the incline motor fuse: Make sure that the incline motor fuse is not blown and replace it if necessary.
  4. Check the incline motor itself: Make sure that the incline motor is not damaged or worn out, and that it is functioning properly.
  5. Contact the manufacturer: If none of the above solutions work, it could be a problem with the incline motor itself and it may need to be replaced. Contact the manufacturer's technical support for further assistance and they may have more specific troubleshooting steps to help you fix the issue.
It's worth noting that this error code is related to the incline motor, so the incline feature may not work and you may need to use the elliptical trainer without that feature until the problem is resolved.
1helpful
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
2answers
Treadmill incline not work
Run please the software calibration for easy diagnostics+and fix it.
God bless you
Sportsart 3000 treadmill problems
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
1helpful
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
7helpful
2answers
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
