LG 32LD320 32 HDTVReady LCD TV Logo
Anonymous Posted on Jun 13, 2012
LG 32LD320-ZA remote sensor
Every now and again the tv wont respond to remote. The remote works on friends tv (same tv exactly). suspect IR sensor on tv. How easy is this to replace please? Many thanks!
  • Anonymous Jun 14, 2012
    thanks for the info, is this a difficult job? Although I do have an electronics background Ive not worked on LCD Tvs..
Anonymous
Level 3:
Master:
  • Master 879 Answers
  • Posted on Jun 14, 2012
Anonymous
Master
Level 3:
Master:
Answers
879
Questions
0
Helped
143326
Points
2676
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
    thanks for the info, is this a difficult job? Although I do have an electronics background Ive not worked on LCD Tvs...
5 Related Answers
Jason Morris
  • 362 Answers
  • Posted on Apr 29, 2009
SOURCE: LG 42LC2D not responded to remote
The IR sensor is in fact a "plug in device" .
The TV will have to be disassembled to replace the sensor.
You should make sure the remote is functioning before you do anything as drastic as taking your tv apart.
I am sure you have tried fresh batteries so the next step would be to hold down any button on the remote, the led light should have a faint pulse, it may be hard to see and you may have to go in a dark room but the led will pulse if the remote is good.
If you have a universal remote, program it for your tv and test functionality.
An RCA universal remote will work with your tv, if the codes don't work do a search with the remote.
If you decide to replace the sensor you should be able to find one at http://www.shopjimmy.com or http://partstore.com.
Let me know if I can be of further assistance.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 10, 2009
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on Jun 22, 2009
SOURCE: LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Anonymous
  • 668 Answers
  • Posted on Jul 16, 2009
SOURCE: I have an LG 37 inch LCD. The remote control
Most of the time it is the Main Board in the TV that the sensor plugs into. They have had many issues with this Board causing this problem. To be sure, you will need to call a professional.
Hope this helps,
Skyassoc
Anonymous
  • 1112 Answers
  • Posted on Sep 29, 2009
SOURCE: Remote sensor on TV (LG 42PM1MA) seems to be broken.
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Testimonial: "Thanks a lot. Seems you've done this yourself :)"
Swapping out a IR sensior for a 49 JVC?
Hi Marvin, I'd suspect main board issues
2helpful
I've got an LG 42LD450-za television that the IR sensor doesn't work on. It brings the set from sleep mode, but no further. Obviously I tried a new remote with the same results... any suggestions?
If the TV responds to the remote, then the sensor is working. Likely you have another issue related to the TV function internally. Check that you have a picture or sound and report back.
2answers
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
1helpful
2answers
Hello I'm finally back again I got a customers LG tv Model #37lg30 it does not respond to the remote the buttons on then side alow us to operate the tv I tried the remote on another
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
52helpful
5answers
LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
1helpful
3helpful
Lone99star
1helpful
Lg fla screen
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
if remote is OK, then the problem with Remote sensor or related components of the TV.
7helpful
3answers
My TV won't respond to the remote control
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
