the di 620 uses the pi6200 fiery i have down loaded the xp print driver but it wont print i am missing the correct print name info i cant find the right ip information helpthe di 620 uses the pi6200 fiery i have down loaded the xp print driver but it wont print i am missing the correct print name info i cant find the right ip information
help
You can't post conmments that contain an email address.
1. Define your Star Micronics Printers device model TSP600 2. Define your operating system to install your Star Micronics Printers device 3. Search Printers driver category 4. Find Star Micronics Printers driver 5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95 6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95 7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95 8. Restart or reboot your computer to finish your driver installation.
dear friend, these are basic steps to install your printer. 1) you need a printer driver cd or driver setup file. 2) run your setup file and follow the steps 3) while your setup is running connect your printer with your computer and give them power. 4) after installation is complete restart your system. 5) done. u r ready for give print
used this link and download your driver and follow these basic steps while installing printer.
What about the starter/developer last time its been changed? Upper fuser/fixing roller (Hot rollers) don't forget to clear counters once those parts are installed.
When you install the driver, do you get a test print from the driver setup? If the data light blinks, this is at least a sign that something is coming and the printer is aware of it. If you feel knowledgeable of the printer to do a Media Sensor setup through the menu, you can reset the printer to Factory Default settings. Getting any print from the machine is a plus. Are you using the Zebra drivers? If yes, you can try printing from Notepad.
Yes there is NO reason why you can't. You must simply install the Printer Drivers on BOTH PC's.
Using the Software supplied, first Setup/Install the printer on your Desktop PC, FIRST, as a LOCAL printer.
Then 2nd, from ya lappy setup your printer as a "Networked" printer.. locate and connect.. the driver will install, & ya can then print a Test Page, to see if it is all OK.
After the Drivers are installed at BOTH locations you will be able to print from your laptop through your desktop to ya printer... no worries..
help
