3M SportsStuff Speedzone 3 Inflatable Towable Logo
Anonymous Posted on Dec 01, 2008
Vinyl air How do you patch vinyl air towable tube?
Anonymous
Level 3:
President:
  • Master 2,336 Answers
  • Posted on Dec 01, 2008
Anonymous
Master
Level 3:
President:
Answers
2336
Questions
37
Helped
756891
Points
8022
I have a vinyl towable tube inflated with air.....I need to know how the best way is to patch this to hold air under pressure
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
3836
Points
5
Your local sporting goods store should carry a patch repair kit.
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: what is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
How do I fix a leak in my three person seadoo tube?
Any sporting goods store can help you with this problem by supplying a patch kit made for this type of toy.
My airhead viper 2 inner tube has a hole, how do i fix it?
If this is a natural rubber tube,the good old bike patch kit will do.If it is a vinyl tube,there is a type A or type B.(Different chemical makeups in different types of vinyl will only adhere to the same type).I don't know how to tell which type of vinyl is which,so get one of each type(at a sports eqipment store).If the first one doesn't adhere,you should be able to clean it off and try the other kind.
How do you fix a leak in a towable?
get a patch kit at walmart or any lowes..it comes in a kit w/glue and sometimes a patch..follow the instructions. glue then put patch on ..use the right time in instructions though
1helpful
2answers
What is the best way to patch a small hole in a towable tube
How to repair a artic rocket
The Arctic Rocket is made of PVC Vinyl. Nothing else will stick. Make sure you slightly scuff the area before you try to patch it.
1helpful
From what is an Inflatable Towable made of?
AN INFLATABLE WATER TUBE IS GENERALLY CONSTRUCTED FROM AN ENCLOSED FLEXIBLE PVC RUBBER BLADDER AND SURROUNDED BY A NYLON FABRIC COVER. MOST TUBES CONTAIN A VALVE THAT ALLOWS THE RIDER TO INFLATE THE TUBE MANUALLY OR BY WAY OF AN AIR PUMP. RIDERS SHOULD LOOK FOR TUBES THAT HAVE ENOUGH HANDLES TO ALLOW THE RIDERS TO SAFELY AND COMFORTABLEY RIDE.
Infatable canoe
Inflatable canoes have considerable appeal for certain uses. When folded they are quite compact and their weight - about twenty to thirty pounds - makes them ideal for toting to remote fishing waters or for storage in today's small car trunks. The better-quality versions are made of heavy-duty vinyl-coated polyester, or PVC, with multiple air compartments (so if one compartment springs a leak, you still have some flotation). Restrictions include speed, since inflatables are relatively slow, and they have minimal carrying capacity. Repair kits are a must on most trips. Also, you will want to have a foot pump to inflate the canoe before starting out.
Top 3M Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a 3M Water Sport Expert? Answer questions, earn points and help others
