Computers & Internet Logo
Gary Foley Posted on Jun 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can dennythedon3003 help - if only he spoke English
Dark screen
Anonymous
Level 3:
  • Sony Master 32,281 Answers
  • Posted on Jun 14, 2012
Anonymous
Sony Master
Level 3:
Answers
32281
Questions
Helped
7905819
Points
102259
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
5 Related Answers
Anonymous
  • Posted on Dec 15, 2008
SOURCE: sony vaio geforce driver
what is the wesite name to download my VAIO-VGN--FE41m laptop
Anonymous
  • 61 Answers
  • Posted on Feb 29, 2008
SOURCE: sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Anonymous
  • 18 Answers
  • Posted on Nov 04, 2008
SOURCE: Sony VAIO PCG-K25 Dark Screen
Do you get the same result if its plugged in or running off battery? Try holding down the "FN" key or function key and using one of the Function keys i believe its F6 on the sony's to brighten up your screen if that doesn't work try downloading and reinstalling your video driver and finally you may have a video card issue
Anonymous
  • 476 Answers
  • Posted on Aug 10, 2009
SOURCE: Sony Vaio Laptop VGN-CR240E LCD screen flickering
Hi - I have replaced lots of LCD screens,it can be done
HOW TO REMOVE LCD PANEL OF MY ACER LAPTOP.
First ===>>> Remove all power and battery
Each machine is different in construction and size,
but they operate in the same fashion,motherboard,power inverter,lcd panel and cable connecting them together,also there may be a wireless aerial and or camera as well inside the lids frame housing the lcd screen so be careful while dismantling the front frame,it should be a good tight fit,
the lid has a base and a front panel covering the workings of the screen and wiring in a compact frame,remove the screws from the front panel and lift the front frame free from the base,remove the power panel by the screen next to the keyboard this should expose the motherboard insides,then unplug the inverter from the screen,unscrew the screws holding the the frame and carefully lie the screen on a flat surface to unplug the data cable from the rear of the screen, top of the screen rear contains IC chips required to make the pictures,
DO NOT TOUCH THESE >>> STATIC KILLS
It dosent mater if the screen is already dead just remember this when you fit the new screen
Hope this helps,Misterdj
Anonymous
  • 591 Answers
  • Posted on Sep 23, 2009
SOURCE: how do you replace a sony vaio ux lcd screen?
Basically remove all screws holding the front bezel (screws are behind the rubber thingies). Once you have pried off the bezel there are several screws on each side of the screen. Removing these will be needed, along with any remaining screws on the top and bottom. Once the screen can be leaned forward, with a sheet of paper towel, on the keyboard. There is a long connector at the top of the screen; remove this connector. Another smaller connector is at the bottom, remove it as well. This ought to get you well on your way!
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
How can you learn to spell dennythedon3003 - CUTOMER is not an English word - could it be your native language? operating system not found, vaio laptop
Looks like the OS is corrupted, but you can restore it by restoring to the previous date, for that you need the OS installation cd. Just insert the cd and wait for few munites to load files, then you will see the restoring option.
Hope this helps, thanks for using fixya!
2answers
How can spammer dennythedon3003 help - if only he spoke English - but no, a big loser
Thanks for asking Fixya !!!!
Remove the battery and connect AC adapter directly then press power button if it didnt turned on then the AC adapter or the DC jack is faulty ..
Regards
Sibu
2answers
Problem since 2010 - how can dennythedon3003 help - if only he spoke English
Windows Vista Audio Drivers:
http://s02.download.sony.com/US/pc/REDAUD-01338701-US.EXE
Windows XP Audio Drivers:
http://s02.download.sony.com/US/pc/REDAUD-01199801-XP.EXE
Download the driver and install then restart computer.
Thanks for using Fixya
dont forget to rate solution
My lcd is dark
If your battery and power suplly are ok, then you have a problem with your screen inverter, or needs to adjust your screen settings. Cleck display settings at your control panel
2helpful
3answers
Polaroid LCD 32" TV
The user manual was no help. I called Polaroid and they help me solve the problem. Very helpful and spoke English which is unusual for customer service anymore.
4answers
Picture problem after changing highe presure lamp
this is the light engine problem. i was able to get mine fixed through LG because its a known issue. this is not a bulb problem.
AFTER 2 MINUTES IT BECOME DARK SCREEN, DOESN'T WORK THE COMMANDS BUT I CAN LISTEN
if you have never changed the lamp, it is time to..the lamp has reached the end of it's life
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
