Question about Endurance TF3i Folding Treadmill
How accurate are the calorie counters on treadmills and cardio equipment?
Any ideas on how accurate the counters are on treadmills and other cardio equipment at the gym? My gym uses Precor equipment and I always wonder how close the display is to the actual calories I'm burning. Obviously it's probably a little closer if you put in your age and weight, but what about basic muscle mass and body composition?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Posted on Mar 19, 2009
    President:
  • 2,336 Answers
They are totally just a toy added feature with no accuracy. They assume everyone burns energy at the same rate which isn't right. It comes down to your own individual bodies chemical composition and reactions. Do your exercise everyday and use digital scales to keep an approximate record. And obviously eat a balanced diet.
Posted on Dec 01, 2008
SOURCE:
The wire on the back of the tridmil triumph 400t came off and it want light up and you can here that it's on but it is not running.
Triumph™ 400T Treadmill ' Academy
www.academy.com > ... > Cardio Equipment & Machines > Treadmills
Rating: 3.4 - ‎67 reviews - ‎$259.99 - ‎Out of stock
The Triumph™ 400T Treadmill features a 1.50 CHP motor and the AEROsoft™ cushioning system.Missing: motorcycles
Triumph 400T Treadmill - YouTube
? 0:31
https://www.youtube.com/watch?v=TZdf5fIAVMU
Jan 4, 2012 - Uploaded by Academy Sports + Outdoors
Visit Academy Sports + Outdoors or academy.com to view theTriumph 400T Treadmill which is featured at a ...Missing: wire ‎back
Triumph - 400T - TM397B - 2011 - FitnessRepairParts.com
Dec 26, 2015 | Triumph Motorcycles
When I press start the treadmill goes for about 1second and stops. Incline/decline works, no error messages. Red flashing light on the control board after the treadmill motor quits. Stops flashing if I...
Contact the store where you bought it. I'm sure your treadmill is covered by the warranty.
Anyway, the next time buy some high quality treadmill to avoid any hassle. I like the treadmills reviewed here: http://www.your-workout-routine.com/cardio/best-treadmills-2014/
Nov 14, 2014 | Exercise & Fitness
NORDICTRACK X9I CALORIE COUNTER IS WRONG
Yes the repairmen is o.k when he says the controllers nothing to do with the calorie counter.
See the block diagram attached, the problem is the display board or upper board. However adjust the REED switch, test for open or faulty, clean it, and tigh very well the connector b) tight the ribbon cable for keypads inside the display board. c) replace batteries from display by new one, with the same polarity, same markay such hybrid rayovac. c) clean the contacts battery.
God bless you
Jan 08, 2013 | Nordic Track Treadmill Motor Controller...
I am looking for a machine to buy for my home that will give me a great cardio workout. Should I opt for a treadmill or an elliptical?
If a cardiovascular workout is what you want, you should get an elliptical machine. They give you a total body workout - with handle bars for your arms and pedals for your feet. You can burn a lot of calories without having a lot of heavy impact on your joints.
Aug 02, 2012 | Exercise & Fitness
I need a schemetic for stairmaster clubtrack510
Go to Gymparts.com they will have tech manual for this unit, but a technical schematic is never provided for any piece of cardio equipment it is consider proprietorial to the manufacturers.
Feb 01, 2012 | RTO Stairmaster Clubtrack 510 Treadmill
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
Endurance TF3i Folding Treadmill Logo
1,247 people viewed this question
Top Endurance Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
tel66421938
tel66421938
Level 1 Expert
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
