I need the real security code for nokia 1209 phone IMEI ..351966/03/778330/2........TYPE .RH-105
SOURCE: model :1209 type:rh-105 code:0559989
i've nokia model 1209 ime no-356047/03/520798/5 pl send master code
SOURCE: nokia 1208 code 0550593 type rh-105 imei
hi,
unfortunately 1208 is a dct4+ kind of nokia phone..so far not supported by any master code or online calculator...the best way you can do is go to a nokia care center to read your code by any of the following gadget ,mxkey ,hwk ,cyclone or universal box...
i hope it will help you ,thanks for trusting fixya
SOURCE: Don't worry there is Solution
Hello, note that,12345 is the factory master code for nokia.
If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Regards, J
SOURCE: i forgot my nokia 1209 RH-105 security code. IMEI
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:Program FilesNSSBackuppm?252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
