Google Android Logo
Anonymous Posted on Dec 01, 2008
Gphone Error Suffering from a Gphone error every time I take a picture with my gphone, this error message appears: "please insert SD card to use camera." The SD card is of course in the gphone, what is wrong with my gphone? why does it keep giving me this error?
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Dec 19, 2008
Anonymous
Contributor
Level 1:
Answers
23
Questions
0
Helped
21572
Points
73
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Jan 21, 2009
Anonymous
Expert
Level 2:
Answers
97
Questions
Helped
110392
Points
262
First of all, see if the handset recognises the sd card....easiest way to do this is go to MENU > SETTINGS > SD CARD AND PHONE STORAGE and at the top you will see the available size if anything. if nothing, try to remove and then reinsert the media card and then try it again. if thats doesnt work, you will have to reformat the card to FAT32
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
1helpful
3answers
Windows xp home addition V2002 SP2 gphone.exe not found
The very first thing we do is to solve your problem about the start-up error. For your information, your operating system was corrupt that is why there is prompt error message appear in the windows start-up. The best thing here to do is to start your computer in safe mode and this can be done by pressing F8 key until a operating system menu will appear. Select Safemode and wait until you get into the User Account Login screen. Enter to your account and then restore your computer to an earlier time. Go to All Programs - Accesories - System Tools - and then select System Restore.
But if this procedure failed, the only last thing should be done is to reinstall your computer operating system. Leave comments for further assistants. okay..
1helpful
Window can not find gphone.exe
gphone.exe is nowadays one of the most dangerous virus spreading very fastly.Its a trojan and changes your IE homepage and sends tries to open gtalk and yahoo messenger.It even sends messages to gtalk contacts.Its icon is just like that of folder icon and people thinking of folder click on it get infected by the virus.
Gphone virus basically is a 260 kb .exe file which looks like a folder and it can take any name of any other folder if you have clicked on the virus folder which looks like a folder but it isnt.If you have a folder name “comptalks” in your D drive it will make a exe file in the folder named comptalks.exe and if you click on that exe file it too work as a virus.It makes .exe files in all the folders you have with the name of the folder.
To remove the gphone.exe virus you just need to follow simple steps:
Go to Task Manager ->Processes and then click on gphone.exe and click on end process.
After that manually go to folder where gphone.exe is present and simply delete it.
Or simply search for the exe file clicking which started sending messages through gtalk. If you clicked on 1.exe search for that file on task manager and then delete it.
Good luck.
1helpful
2answers
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
17helpful
3answers
Windows cannot find gphone.exe??
Gphone.exe is a file that an instant-message worm infects. This worm spreads through Google chat and Yahoo! Messenger. This “Gphone.exe” worm disables your antivirus security software, and downloads more crapware onto your PC.
To remove do this:
1. Block Gphone.exe sites: http://rnd009.googlepages.com/
2. Stop Gphone.exe processes: %Windir%\gphone.exe
%System%\gphone.exe
%System%\DEFAULT_NOT_SET.exe
C:\Documents and Settings\All Users\Desktop\gphone.exe
%Temp%\gphone.exe
%System%\gphone.exe
%DriveLetter%\New Folder.exe
%DriveLetter%\gphone.exe
[ROOT FOLDER]\New Folder.exe
[ROOT FOLDER]\gphone.exe Get rid of Gphone.exe files:
%DriveLetter%\autorun.inf
%Windir%\Tasks\At1.job
[ROOT FOLDER]\autorun.inf
C:\disk.txt
%System%\autorun.ini
%System%\setting.ini
%Temp%\log_[TIME AND DATE].txt
3. Delete Gphone.exe registry keys using regedit from start - run:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\WorkgroupCrawler\Shares\”shared” = “[ROOT FOLDER]\New Folder.exe”
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\”Yahoo Messengger” = “%System%\gphone.exe”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\”Shell” = “Explorer.exe gphone.exe”
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”AtTaskMaxHours” = “0′
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”NextAtJobId” = “2′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableTaskMgr” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableRegistryTools” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\”NofolderOptions” = “1′
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Page_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Search_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Search Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′ Note: In any Gphone.exe files I mention above, “%UserProfile%” is a variable referring to your current user’s profile folder. If you’re using Windows NT/2000/XP, by default this is “C:\Documents and Settings\[CURRENT USER]” (e.g., “C:\Documents and Settings\JoeSmith”). If you have any questions about manual Gphone.exe removal, go ahead and leave a comment.
How to delete Gphone.exe files in Windows XP and Vista:
1.Click your Windows Start menu, and then click “Search.”
2.A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
3.Type a Gphone.exe file in the search box, and select “Local Hard Drives.”
4.Click “Search.” Once the file is found, delete it.
How to stop Gphone.exe processes:
1.Click the Start menu, select Run.
2.Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC.
3.Click Processes tab, and find Gphone.exe processes.
4.Once you’ve found the Gphone.exe processes, right-click them and select “End Process” to kill Gphone.exe.
How to remove Gphone.exe registry keys:
Because your registry is such a key piece of your Windows system, you should always backup your registry before you edit it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or value, there’s a chance you may need to reinstall your entire system. Make sure your backup your registry before editing it.
1.Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
2.Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
3.To find a registry key, such as any Gphone.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Gphone.exe’s registry keys.
4.As soon as Gphone.exe registry key appears, you can delete the Gphone.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Gphone.exe DLL files:
1.First locate Gphone.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
2.To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Gphone.exe DLL file is located. If you’re not sure if the Gphone.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
3.When you’ve located the Gphone.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Gphone.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Gphone.exe change your homepage?
1.Click Windows Start menu > Control Panel > Internet Options.
2.Under Home Page, select the General > Use Default.
3.Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
4.Select Apply > OK.
5.You’ll want to open a fresh web page and make sure that your new default home page pops up.
Gphone.exe Removal Tip
Is your computer acting funny after deleting any Gphone.exe files? I recommend using a program like File Recover from PC Tools. File Recover saves deleted files that otherwise can’t be recovered by Windows operating sytem.
Want to save time finding Gphone.exe files? Download Spyware Doctor, let it find the Gphone.exe files for you, and then manually delete Gphone.exe files.
Cannot find gphone.exe
gphone.exe is a virus that affect google talk or yahoo messenger, to remove it you can download a copy of Eset antivirus.
You could have the same error after the antivirus removal but now the system is clear and you have to delete gphone.exe from your startup files list: start -> run -> msconfig -> go to startup and uncheck gphone. This should help you.
WINDOW CANNOT FIND GPHONE.EXE
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:\windows\system32).
Go to this website if you need further removal instructions:
http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
4helpful
Windows cannot find 'gphone.exe'
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
3answers
Gphone video problem
It's not possible to record videos for now. it will be probably come soon in an os update or in 3rd party app. Just be patient or start coding! ;)
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
