Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
There are end sensors in the unit that are fed by a lamp and they burn out - I am guessing the lamp is out in the center of the tape. There could be other reasons but without seeing the unit I can not determine remotely. I have repaired thousands of VCR in my 40 years in service.
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
Many parts are still available on these camcorders however if it needs a video head for example, and it's not avaiable it may be a better idea to get another 8mm camcorder off ebay, or maybe a pawn shop. just test them with a new blank tape first before putting your family tapes in.
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
I work at the History Channel and have a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
The idler wheel (that only drives the tape in play or scan modes) is
slipping too much (very common problem). Try verify this by
putting the tape in play then immediately press the fast fwd or rewind
buttons to scan the tape. On older machines, the idlers used
rubber friction tires - on newer ones, a clutch. Either replace
the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
