I have a ge profile 24 inch built-in that drains completely (I checked can see the water draining into the disposal and opened door during cycle to see the tub completely empty) during the wash and rinse cycles, but does not drain the final cycle. I know it's supposed to retain a small amount of water, however the tub is completely filled.
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Catriver: The dishwasher model is gsd5920do1bb. I probably posted the original problem in the wrong place. Does a similar fix apply? Sorry about the confusion. Greg
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
Hi, 1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dishwasher doesn't drain in final cycle
After running through a cycle it doesn't completely drain
the water doesn't drain during the rinse and hold cycle
I have disassembled it, replaced the drain screens (pretty clogged with hard water deposits), inspected the check valve, removed and tested both motors by applying 110V, and used test lamps to verify there is power to the motors during the cycle. It still doesn't drain. Any ideas on anything else I can check would be greatly appreciated!
dishwasher has water in bottom after cycle is complete. takes 2 1/2 hr to wash
At end of cycle, 1-2" of water in bottom of tub. How to drain this.
water flows into tub and drains. wash cycle does'nt start.
