Is this TV fixable - manufacture date Oct 2001. Gets 2-3 code (deflection error). What are the steps to take to determine problem and replace components?
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
SOURCE: Mitsubishi VS-50705 TV has error code 23, Horizontal Deflection failure...tv won't turn on.
Unfortunately, problems in the deflection circuit can involve expensive parts. This type of repair is not for the do it yourselfers. It requires proper test equipment and diagnostic experience. Look to spend at least $350 and up. Maybe Santa will bring you a new plasma for Christmas. Good luck
SOURCE: deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
SOURCE: I own a Mitsubishi HD 1080 series HD TV;
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Testimonial: "Thank you very much for the advice. I agree it may more cost effective to "bite the bullet" and buy a new TV."
