SOURCE: GE fuf14sverww Running continuously, bottom stuff
It is a faulty thermostat. An open thermostat defaults to a high value,
so it does not shut off. If it was a bad compressor, or low in freon,
it would not "get ice cold". If it is low on freon, the low pressure
switch would not let it start up.
The defrost timer either runs normally (cycles on and off cold) or is in
defrost mode (heater elements turn on to temporarily heat the freezer
in order to remove frost). Anyway, It is not the defrost timer if it
"gets icy cold".
Unplug your Refrigerator remove the thermostat and take it to your local
parts store. Hopefully it is cold outside where you live, if so you
may put your food in a cooler outside your door until you replace the
thermostat which you will find is an easy task.
Regards.
