I re-intalled windows vista and sypnatics pointing device driver but the AV mode bar sensor iis not working. What driver do I need to install to make it work. (Sony Vaios VGN-CS108E - Vista x32)
SOURCE: need driver for sony vaio VGN-CR220E built in web cam, motion eye
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
There u go, all availble files for Vaio VGN-CR220E and Vista
Good luck
SOURCE: XP Drivers for Sony Vaio VGN-fw230j/b
It's probably not supported Sony.
You can try and downgrade but you might lose some functionality. I downgraded my Vista Gateway laptop to XP but had to spend a lot of time tracking down drivers that would work correctly.
You won't be able to just pop in an XP cd and install. You'll have to jump through a few hoops.
Here's the biggest hoop and guide here:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Since you have a newer laptop your hard drive uses sata drivers which the XP cd doesn't have built-in.
Let me know if you get stuck or have anymore questions.
SOURCE: VAIO VGN-AR630E Drivers for Vista Ultimate
try going to the official site of vista and see if it can help lol or just reverse the process lol
SOURCE: Sony VAIO VGN-CR320E Motion eye camera never
Have a look in device manager
Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc
have a look under imaging systems click on the + sign and see if you have a Camera listed
Also on Sony they should have supplied an application for the camera
maybe called ArcSoft WebCam Companion - see if you have that program folder - listed at all
SOURCE: I have a SONY VGN-CS215J,
Try this..
You can also try downloading and installing the Touchpad Driver.
You can download the Touchpad Driver here.
hope this helps....
