Power Acoustik G320-2 Gothic Series
If you're geting no lights on the amp, you need to confirm that you have voltage at the amp. If you haven't done so yet, check the on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Can I strap a3500d Gothic to a 6000d gothic
