My camcoder is 4 yr old. It was working fine, recently it stopped playing back recorded video. When I select play mode, it displays blue screen with time counter running and no audio. All other functionality seems to be working. I can record the video, after recording video if I directly go to play mode (with out turning off) then it displays recorded video with blue horizontal tripes and no audio. If I turn off camcoder and again go to play mode it displays blue screen and no audio.
How can I fix this problem?
thanks
SOURCE: Panasonic Palmcorder PV-GS15 Software
What u need at the minimum is an addon card for downloading(refer to the manual for the exact No. it is something like IEEE1395 or so) Then connect the cam to this thro' the cable.
If u use windows xp u have a movie maker. u can use that s/w. Else try to get pinnacle studio or studio 8 to dump and edit etc.
all the best.
SOURCE: How to download video file
you need software i use Pinnacle Studio it the best one i think help this helps
SOURCE: PANASONIC SDR-H40P (Write Proctetion)
I had the same problem while trying to delete video off of the camera's hard drive using the VideoCam Suite software. I never could figure out how to do it using the software. However, you can delete scenes from the hard disk directly in the camcorder using the menu. For instructions, see page 59 of the manual for this camcorder at http://service.us.panasonic.com/OPERMANPDF/SDRH40P-MUL.PDF Good luck!
SOURCE: Need the software for Panasonic PV-GS15
Anyone have any idea where I can get the software for a Panasonic PV-GS15, to be able to pull video from my camera to my PC? Or do you kno w any way around software??
