Same problem with the HL-2070N. Hope we get an answer...the cartridge has 5000 pages left on it.Same problem with the HL-2070N. Hope we get an answer...the cartridge has 5000 pages left on it.
Check for a piece of paper caught in the fuser section. Sometimes a small piece will wedge itself in. Vacuum out any residual toner that may be in the paper path.
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
You may have a small jam or a piece of paper that is still inside the printer. You may have to look for a smaller piece of paper. I have had this happen to my laser printers before and it was because there was a plastic arm that is inside the printer that came loose during a paper jam and it wouldn't accept paper until I reattached the arm and then the printer would accept the paper.
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam. Removed it and now I have the green light.
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
That is not the problem thanks
What do you mean by the "fuser" section?
