SOURCE: how to connect power sw and led and reset sw and
You'll need to go to the Elitegroup website and download the .pdf file showing a diagram of the motherboard wiring layout and pin connections and then connect the wires from the case to the proper locations.
SOURCE: where does the HDD Led, Power SW, Reset SW, and
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
SOURCE: what colors are the wires
- the colors of the wires (can differ, depends on the case type):
Testimonial: "thanks alot"
SOURCE: i want to setting power
On the motherboard should be marked what goes where. I do not suggest you doing this. Experts do this without manual because they know what they are doing, but I understood that you are a rookie. But if you decide to do this by yourself, here's how:
Go to this link and download manual:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?detailid=269&MenuID=0&LanID=9
SOURCE: I cleaned my pc, and disconected the wires that
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.
