I have tried unplugging and plugging back in but still have same problem
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
SOURCE: 48" Toshiba Projection TV
If you keep whacking it, you'll NEED a repairman!!!
Really, the question you should ask yourself is, "Am I wanting to spend money to fix this set or invest in a new one?" Since I don't know your financial situation, I won't go there, but I would suggest that you maybe contact a TV repair person, have them come out, look at the set and give you an estimate on the repair costs. The trip out and the estimate may cost you a couple hundred bucks, but you then have the information necessary to decide which way you want to go.
Personally, if the cost of the repairs approach about 1/3 the cost of a new set, I would opt for the new set -- so if it would cost me about $700 or more to fix the old one, I could see a new set in my future. If it would only run $300, I may get the old one fixed and get another year or two out of it. By then, the prices on the larger sets would have come down, the options and selections would have gone up.....
