Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
red n white phono leads from deck 1 to channel1phono ports on mixer
red n white phono leads from deck2 to channel2 phono ports on mixer
then output out to amp
on top of the pitch control there is a small hole, in this hole you can use a small screw driver and turn it left and right to free any dirt inside this is the master pitch control
