Sounds like water hammer. There is a small (very small) water hammer minimizer built in the Single and Dual brewers. If your looking at the water valve there is a small 1/4" copper tee with one end sticking upward. This usually has air trapped inside and tries to soften the water pressure as the valve open and closes. There are larger ones mounted in the bigger urns like the U-3 brewers. Though it's easier to have the plumber install a larger one at the mains to take care of the whole restaurant.
* It is possible to replace the copper water line (to the brewer) with a reinforced flex hose that will take up the initial pressure of water hammer but if you are running high water pressure then there is a danger of the hose bursting. Might be better to go with an armored hose (those used under sinks)
* There is one more thing is the water probe is getting too sensitive. Have the tech replace the water level board. He will want to do this as the constant clicking of the water valve will cause it to fail (like in a month or less)
* High pressure can cause sloshing in the tank. This creates waves in the tank but normally the water level board will ignore this splashing on the probe. Have the tech check and clean the probe anyway. It may be possible to reduce the flow rate to the brewer (thus the water hammer pressure) by adjusting the valve that supplies the brewer. Be sure to have the Tech label the valve as someone is sure to come along and open it wide again..
Aloha, ukeboy57
PS; double check if the valve is rated for your water source. Hot water supply requires a different valve (it's bigger too.). Most come with the standard cold water supply rated valve. ukeboy57
SOURCE: will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
SOURCE: Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand. That should take care of it.
SOURCE: Water fill light stuck on
you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: Changed Claris Filter-now says "fill system/press steam"
Probably have air in the system - it needs to be flushed, Run the tea portion hot water for a while. If not check the manual on how else to flush the system Gary
