There doesnt seem to be a seperate audio out red/wht for sound out to the surround system as there is on my 42" vizio. is there any way to make it work?
SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
SOURCE: Wharfedale LCD37F1080P and external surround sound
SOURCE: Vizio Sound Problem
i got for christmas a vizio 32 inch tv..we are having a hard to hooking up the surround sound anyone who can help us out !!
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
SOURCE: Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
