Hotpoint BWM12 Front Load Washer Logo
James Posted on Jun 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door handlen can't open
Level 3:
  • Hotpoint Master 17,130 Answers
  • Posted on Jun 12, 2012
Hotpoint Master
Level 3:
Answers
17130
Questions
0
Helped
3635239
Points
52372
1997 Jetta Passenger Door is stuck closed
sounds like the linkage came apart on the inside of the door. Remove the inner door panel & u will see the linkage probably disconnected. find out where its disconnected & reconnect it. there may be a clip which holds it together which u may find in the bottom of the door.
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
2helpful
1helpful
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
1helpful
Door motors (controls for the seat adjustment & window operator) won't work unless either the passenger or the driver door is open. How to fix?
take to dealer system is hard to diag even with all info at hand because each door and window has sensors that send singals to a body control that processes and then lets work.
Door is locked & we can't open it, how to open the door
I am an svc member, i want to know more about vikings.
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door error and it keeps on coming while closing the door with a beep . Can anyone please try to resolve the error...
seems like your primary switch isn't closed correctly or it might bad.
step to trouble shoot
OVEN HAS 5000 VOLTS MOVING INTO IT PLEASE BE CAREFULL
1.press back key to turn off the oven.
2.Open left side pannel.
3.press 'back' and 'enter' key together.Then, enter 9428 and then press enter.
4.You will be directing to an testing screen.At the bottom of thetesting screen there are many alphabets.In which you can see 'P' ,'S' and 'M' .
5.Open the door and watch what happened to alphabet 'P'.I meant to say that when door open alphabet will highlited ,and when closed its seems an regular 'P'
6.open door and close the door .And also keep an eye on the primary switch at the top left corner of the oven where the door latches engaged.If it engaged very nicely and you still see an highlited 'P' in the testing screen then REPLACE THE PRIMARY SWITCH OR IF SWITCH IS OKAY THEN CHEK THE WIRING UPTO MAIN BOARD.
7.If switch doesn't latches properly then adjust switch ,by lossning the screw and aligned it properly.
PLEASE LET ME KNOW IF YOU KNOW HOW TO USE MULTIMETER,SO I CAN EXPLAIN YOU HOW TO CHECK THE SWITCH.
ALSO PLEASE RATE MY ANSWER.
THANKS
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
