I am not a pro...did this process early today.
1.Remove 5 screws from bottom center dash. This peice has the cubby with change slots. There are 2 on the left side, 2 in front and 1 on the right. Pull out of the way.
2.Pull cup holder all the way out and depress tab on the very back of the top. Slide out and remove.
3.Pry small peice of plastic out of the way carefully with screwdriver. Remove.
4.Revove 2 screws that where hidden by this small part. Begin prying the dvd and
radio surround off from the bottom, there are no more screws. Either let dangle to the side or unplug and revome from car.
5.Remove 2 screws to release dvd player. Unplug 2 seperate connections and remove. If you have change in it, shake upside down a little while slightly depressing the top to give room for $ to fall out. For 2 dvd just work out carefully while trying to line up the dvd with the opening.
Hope this helps someone! Kris
where can I send it I was told they don't fix them just replace any help will be appreciated
